Engine bay liner?
Bigbird
Anyone use raptor liner in their engine bay, or something similar? Just wondering how it would hold up to the heat.
Timtree
Loxahatchee
I have used it on jeep builds previously to this. U-pull raptor tintable bed liner. Did the tubs and under the hood. Looks great and holds up never had an issue with the heat. But it's not really that close to the headers anywhere. Running a 355 aluminum heads and griffin radiator so it puts out head in south florida in the summer.
Hope this helps
Semper Fi.
5811 8yrs
Bigbird
Bigbird
Right on. Thanks Timtree.The reason I'd like to use Raptor under the hood is because my fender aprons aren't show quality and that might hide some of the imperfections.
Timtree
Loxahatchee
It will show the outlines of any imperfections but I have learned to take seam sealer and smooth out any thing and it works great. Extremely easy to spray. I will defiantly use it again.
Timtree
Loxahatchee
No I ran the sealer over top of the primer. Not sure if that is what is recommended but that is what I did. Maybe a body guy can chime in.
No issues up to this point
rfoleygearhead
You want to put the sealer over the primer because the that type of sealer is a silicone base the prime will not stick to it
