Engine Cage Coilovers setup?
Jonz612
Peoria
i am building a 1966 half cab and i have a set of 12" 2.5 King coil overs for the front. i want to get some ideas for the mounts on the axle and the towers and engine cage.
bowhunter
Well....if you were closer, you could run over to BailieBilt and take a look at his.......but!?!?!
MpCrewcab
Jefferson, WI
Couldnt find pics of the mount on the axles, but here are a few of the hoops and then the tie into the cage and engine surround. There is then unboltable bar that goes across the motor and attaches to both shock hoops. Post up if you need more pics. These were a few of the build pics from a few years ago.
