707Bronk
- Mar 18, 2012
- 590
as was said but even with a resistor a coil can still overheat. when the ignition is left on. You said your coil was a pertronix so it should have internal resistor already. ro it was just a bad coil from the get go and failed early.
While the coil may not be harmed by leaving the key in run with the engine off, the module may get fried.
The Pertronix I module can still be fried by leaving the ignition in run.
I believe the Pertonix II module prevents this.
