Hal9000
So I'm just getting my '69 w/ 302 running after a long, long, hibernation...
The engine starts with difficulty right now. I basically need to use starting fluid every time when it's cold. But once running, the idle is stable and it revs nicely.
At the engine warms up however, it developes an ever worsening off-idle flat spot that eventually gets so bad that you can't open the throttle without the engine dying. And it gets harder and harder to re-start as it warms up. By the time the temp reaches 190, I usually can't get it to re-start.
Also, I've found that I can't ever open the choke all the way or the idle gets choppy and deteriorates till the engine dies.
The engine has a Holley carb. I think it's the standard 650 cfm 4bbl that everybody used to use, but am not 100% sure.
If anybody has any ideas on where I should start, or what might be the problem, I'd love the help.
