kontinu
I just got the bronco on the road and am trying to work out some of the bugs. Sometimes I can start the bronco, runs and idles smooth. After driving it for a little while the rpms just drop and it stalls. As soon as I let off the gas it dies. I can keep my foot on the brake and a little gas and keep driving it but something is not right. Sometimes it starts like that and I can't even drive anywhere. It seems that after it sits for a day or 2 it will run fine to start then acts up. I put a new vacume advance on it and no difference. I messed with the timing and it seemed to be ok as well. I took the vacume advance off plugged it up and set the timing to 8degrees I think. When I put the vacume advance back on the idle went up a little. I drove it around andafter a while the same thing happened. It doesnt pop or backfire when it's running good or bad
