engine keeps stalling
lasadoor
San Diego
My engine was idling at a high speed, and it would to stall on occasion, I found a plug wire that was bad, so I changed all the wires checked all the plugs, and had the timing reset. The engine ran great for a time.
I was inspecting the fuel lines and found one that needed replacing. I switched to the auxillary tank, which I rarely use, replaced the line and switched back to the main tank.
Now the engine sounds fine at idle, sometimes runs great, and sometimes stalls, surges, and back fires. I have checked the plugs, wires and connectors. The PCV valve has good suction, but the metal piece inside seems to rattle quite a bit. Tomorrow I'll spray some carb cleaner in the oil filler cap, and inspect the fuel filter. But I am stumped.
The engine is a 302 was rebuilt about 18 months ago, and still under warrantee, but that doesn't include anything electrical or fuel related.
Dief1968
Just had the same problem with a Bronco I was looking at. He has an Edelbrock carb. Took the top off and found gunk in there. He had not been running a filter. Now he is and the it runs great. As for backfiring, I would check the cap and rotor for cracks.
lasadoor
lasadoor
San Diego
checked everything again this morning, bronco started right up no issues. looked inside carb everything thing looks nice and clean. no cracks in the dist. cap either. pulled the fuel filter, its yellow now i don't know what that means it looks okay otherwise and the plugs have carbon deposits on them. is it possible that the coil is going bad? do i need a new fuel filter?
12-Pack Jeff
La Mirada, Ca
maybe a vac line or cap is missing, broken or corroded. If you havent used the fuel in the aux tank for a long time its possible you gummed up the carb. I'd switch between them every tank of fuel if it was me... Although I've ran things with several month old fuel, I've also had to disassemble and clean every orifice of carb's from gumming them up that way too...
ugly74
Bronco abuser
Colorado
if you even have to ask, "should I replace the fuel filter", chances are, you should replace the fuel filter. if you hardly ever use the aux. tank, you may even have to go as far as taking the steps necessary to totally clean it.
lasadoor
lasadoor
San Diego
I was thinking the auxillary tank may have fouled things up a little. I checked out the carb this morning and it looked alright. I drove around for about an hour today and it ran fine.
-does the PCV valve supposed click/rattle
-does the fuel filter discolor over time is this "the" indicator that it needs to be replaced
ugly74
Bronco abuser
Colorado
if the PCV does NOT rattle, it's gummed up and should be replaced. rattle= good.
if the fuel filter used to be clear plastic and is yellowed, it's an indicator that yes, it's old and you could use a new one. if just the element is yellow, hard to say cuz they're normally yellow paper anyways. but they're cheap, and if you haven't ever done it, just do it and get it out of the way so you're not always wondering "should I?"
lasadoor
lasadoor
San Diego
its only the element in the filter that has changed, but i replaced it recently.
thanks for the help and advice.
Pa PITT
Stephenville TEXAS
What motor and carb do you have ..
PCV is good when it rattles ..
Filter is so cheap just replace it in these situations .
Is air filter clean.
Do you have 84 oct fuel in a motor that needs better fuel.
On the 2 bbl carbs that have have the plate under them you need to make sure the gaskets under the carb is good and gasket under the plate is good if it has a plate.
Describle stalling..
lasadoor
lasadoor
San Diego
302 engine i thinks its a motorcraft 2150 carb (don't see any markings, but it matches diagram) when it stalls the engines cuts off completely at once no shudder or anything.
I'm thinking more and more about the auxillary tank never being used until recently. That's when the trouble really started up again.
Thunder Chicken
sounds like fuel to me....somtimes you can suck a small piece of crud into the fuel line/ filter and it gets josseled back and forth,...doesent always line up just right to inhibit the flow.... but when it does ...whamo engine is stalled
id drain all the old gas in the aux tank and check lines and filter real well.
