Just got the block from the machine shop
92 Mustang motor with computer and harness (A9L)
Over time have purchased:
GT40 Heads
Mustang Cobra computer (X3M), Upper and lower intake
ZF Tranny
35 tires
Stang buddies steered me into building a Cobra motor because it had more torque and less horsepower.
93 Cobra vs stock stang - had 1.7 rockers and a different cam
I am about to build
My dilemma
Find a Cam comparable to the Cobra specs and 1.7 rockers and use with Cobra computer and 24 lbs injectors (attached it the cam specs for stock and Cobra)
Or
Use stock Cam and stock 1.6 rockers and stock computer (A9L) and 19 lbs injectors
I know that the computers are tuned for the appropriate injectors 19 vs. 24lbs
I would think the computers are also Cam specific?
I had read a thread on here where by Ryan the EFI guru had mentioned using the A9L computer with 24lbs injectors and his MAF that was calibrated for the 24 lbs injectors.
There is an article on his site that discusses the drawbacks of using MAF’s to trick the computer to allow the use of larger injectors. ( I do not know if his tricks the computer or not) . I am not advocating the use of larger injectors but I have all the parts to go either way.
I am not very knowledgeable with respect to Cams
Any help would be appreciated
GT40 Heads
ZF Tranny
35 tires
I am about to build
My dilemma
Or
