EveBYoung
It's possible I may be getting a new EB, and maybe one that'll need an engine rebuild so I've been researching that quite a bit, but I've really only learned enough to have a lot of questions haha.
It'll be a 302, and so far I'm pretty sure I want hypereutectic pistons, moly rings, motorcraft spark plugs and wires, a new timing chain from edelbrock or comp cams, a replacement oil pump and oil pan kit from WH, new gaskets and bearings, an explorer serpentine setup (power steering pump and bracket, timing cover, alternator with pulley, water pump with pulley, crank pulley, harmonic balancer, passenger side alternator bracket with tensioner and lower idler pulley, driver side power steering and A/C compressor bracket with upper idler pulley, clutch and fan, ALL of the mounting bolts, Felpro TCS 45449 Gasket kit, high pressure hose for the power steering), a bosch electric fuel pump, new bearings and gaskets, a bcb heavy duty 3-core copper radiator and a holley 470 cfm truck avenger carb.
The truck would be mostly street and a little light trails. I'd want it to be a very reliable driver.
Here are my questions:
1) Will Aeuroquip high pressure hoses work with the explorer serpentine system and hydroboost? I know custom hoses are required.
2) I've read that AFR 165 aluminum heads are the best but I've also read that they aren't necessary and the GT40s are just as good. Which is true?
3) Eventually I want to go EFI but I don't know when that will be, so what should I do about the cam, intake and ignition? I'd like to get a comp cams custom ground cam but I'm not sure how to do it since eventually the engine will be fuel injected (but that could be far in the future). As for intake I've read that while edelbrock is the best for a carb setup that GT40 is best on EFI, and for ignition I've read that duraspark is best for carb'd but tfi is best for efi (and impossible on carb'd). So I'm a little unsure what I should and shouldn't spend money on until EFI happens (but once again, that could be a long time).
4) Finally I'm wondering how everything should be matched to get the right performance and also the right compression to use regular gas - heads, valves, pistons, cam etc.
It's a pretty involved set of questions I know; hope someone can help me out a little. Right now this is all just planning so I can crunch numbers and see if I can handle/afford this haha. Thanks a lot
Rett
Rett
