Engine running without vacuum advance hooked up?!
bsquared
My neighbor and Bronco brother, ZachAttack, has a 68 w/ a freshly rebuilt 289 motor in it. Runs pretty damn well w/o the vacuum advance hooked up to the distributor, but seems to be vapor locking once heated up. Timing looks to be about 10 degrees BTDC at idle. (a rather rough idle at that)
I don't get it. Tried to hook up a vacuum tube to the (looks to be original) distributor and it didn't want to run at all, but appeared to go to 30 degrees BTDC at a fast idle. Has a fairly new Summit Racing 600 cfm carb on top.
Couldn't get it to run right at all with the advance hooked up, so we plugged it to get the Bronco back in the garage.
I suck at trouble shooting carb and timing issues, but I know it can't be right running without vacuum advance. I suggested going to an electronic ignition for a first step and am thinking something's not right in the original distributor.
Got a nice shot of our EB's on a toasty Houston eve.
Any help and / or suggestions are appreciated! B2
broncnaz
Vacuum advance is just a filler it help you run a little bit better but its not needed. but it does help especailly putting around town. Your issue is your hooking up the vacuum advance to manifold vacuum which will advance the timing at idle speed you need to find a port that doesnt have vacuum at idle.
73azbronco
Make sure the vacuum you use is metered off the bottom plate of the carb. Sounds like you r hooking it direct to vacuum.
