BuffDragon
I've got a mild 302. nothing fancy. no smog crap, small 4 barrel on the top.
existing setup is dual exhaust. stock manifolds thru 2" pipe to super quiet mufflers, then out the back 2" pipe. pipes/mufflers run on either side of the driveshaft, then straight out the back on either side of the rear tank.
its too quiet, as it was set up by PO as a hunting rig.
I'd like a little rumble since its now mostly a sunny day cruiser and ranch toy.
buddy of mine hooked me up with a pair of stainless magnaflows. single 2.5" in/out.
what's the best way to do this?
I'd kinda like to run either 2.25" or 2.5" pipe all the way from the manifolds, but I have concerns about that:
1: what do I need to hook up to the manifolds (since existing is 2" pipe)
2: is there enough backpressure running 2.25/2.5" the whole way or should I stick with the dual 2"
3: would I be better off crossing the driver's side over to the passenger's side and running both mufflers under/on that side to get away from the fuel lines/etc
4: if I put downturned dumps on the mufflers, will I get fumed in the cab with the top off?
thanks for the input yall.
this isnt a high rpm racer and I'm running a np435, so I've got low power (gearing) when I need it off road.
I remember seeing someone that did true duals all under the passenger side, but cant seem to find the pics and the thread about it.
