I have a 347 stroker with Ford EFI. 97 Explorer electronics. I been having a random miss or acts like it’s not getting fuel. The scanner shows a TPS fault, I ordered a new. While trouble shooting, key on run not started the fuel pressure goes to 30 PSI , then with key left on the pressure drops to zero . Is this normal? I have never noticed this before. It has a BBK adjustable pressure regulator. It is a return system. Should the PSI hold and stay with the key on ? Maybe the regulator is bad ?
