Explorer alternator help.
burntfish
ouray, co
I have a classic RJM harness that will be going on my 97 explorer engine swap. Do I have to have a 4G Alternator Harness or can I just use the plugs on my alternator and put a Weatherpack connector to match the harness.
ScanmanSteven
RJM has a pigtail to use the 4G, I could look at mine tomorrow and try to tell you what youi need.
Viperwolf1
electron whisperer
You can use the existing 3 terminal connector (only 2 are used on the 4G) and run the green wire to the RJM connector. I highly recommend either making or buying an output cable (to go to battery) instead of using the stock output wire.
needabronco
Prescott/Farmington
The yellow wire goes to the battery, or back to the charge terminal on the alternator, the white wire gets removed and not used. As said the green goes to the RJM harness with a weather pack connector.
I had a fluke charging issue last week at the Stampede where the plug shorted out internally and the alternator would not charge. A wheeling buddy just happened to have another plug zip tied to his wiring harness in his engine compartment.... Moral of the story is carry a spare plug, they are cheap.
toddz69
Good info to know - I guess I'll pick one up when I hit the yard the next time. This was the plug that plugs into the regulator?
Todd Z.
WorkerBee
Northern CA
When I bought the Ron Francis harness (rjm clone) I believe it came with the corresponding weatherpack connector for the green wire. I used the existing 4G plug and installed the weatherpack they gave me to plug into the alternator provision of the harness. I jumped the yellow wire to the output terminal upon the recommendation of Viperwolf. Piece of cake and I can remove the entire thing in 5 seconds. Here's a close up to show the wiring.
burntfish
burntfish
ouray, co
Thanks for the info guys. I have a case of Weatherpack connectors at work. I just wanted to make sure there was not any resistors hiding in the harness I needed or something else weird.
