- Jun 8, 2010
- 2,159
I'm having issues with my 4r70w downshifting when I let off throttle. Even if I'm cruising at constant speed. So I figured the PCM is having trouble with what the transmission should be doing. I bought a vss from an 80's bronco but I'm not sure if it's the 5v that the computer reads. The explorers vss is on the rear end and sends signal to the abs module where it's converted and sent to the PCM. If I CAN plug this vss directly to the PCM, one wire goes to pin 58 I believe, but what is the other wire?
