Do you remember what size hose? I bought some 3/8 EFI hose and it’s way too loose on there. Seems to be 11/32 hose but I can’t find any EFI hose in that size that’s not 25’ long.
Gotta use 5/16. Make sure it is high pressure hose and clamps. Use good quality stuff; you don't want high pressure fuel to spray everywhere. I've used the stuff from NAPA.
YES, EFI hose but make sure you use the high pressure hose CLAMPS. I used two on each end because I get worried about fires... I also run 60 psi to my injectors
I'll hit Napa for some 5/16 efi hose and clamps tomorrow. The original hoses were suspect to start with, then I tig welded a -6AN fitting on the feed side and it melt them to death, which I figured would happen.
I tried some gentle persuasion with heat at first but it ended up getting cut off at the base of the flange. Counter sunk fitting slid over the tube and tig welded up. I’ve done other lines this way and it’s worked, hopefully this does the same.
