you can potentially take the lines that run down the valve cover and flip them to run down the back on top of the trans bellhousing. this takes some careful creative bending of the lines. (they bend easily, just don't kink them). make a couple brackets to hold them in place and connect the lines to the lines you ran from the tank somewhere around the proportioning valve area. this pretty much completely hides the fuel lines and since the original ones already have flex line on them, then you can save $ on fittings and braided fuel line. i did this on my 66 f100 and it works. bronco may be a bit tighter, but i assume can be done.
