Installing the Explorer engine with the explorer serp setup. I am having the issue with the lower tensioner pulley hitting the frame crossmember.
It's not the pulley though, its the bracket behind the pulley and it's hitting the triangle piece that supports the crossmember.
Can I grind on the bracket or is the spacer between the engine and mount th fix?
If I space the motor mount, do I space both sides at the same time or just the passenger side?
Thanks for the help.
