Explorer parts to keep?
Gatordog
Rio Hondo, Texas
I have a complete 2000 Explorer 5.0 AWD and was wondering what parts other than the obvious I should keep?
I have pulled the following:
Motor, transmission, transfer case, ecm, engine wiring harness, transmission wiring, complete A/C system (still all hooked up)steering column. I will pull the fuse block tomorrow.
My question is what else should I pull?
I plan on just using the motor and serpentine belt system with a carburetor and distributor, and staying with the C4 for now, but might go with the Overdrive later. It is very hot here, so I would like to run a AC system.
Redbark
I'm considering buying a 96 explorer with a 5.0 and I have the same question. What parts should I keep from the explorer for my bronco project?
sanndmann3
Rear axle has value to jeep guys and rear disc are worth grabbing for a future upgrade...
