recoiljunky
Couple of questions:
Do you have the right fitting?
If so, why do you think it's too long??
If it doesn't seat properly with the o-ring and depth wise, I don't think it will work properly. When I didn't have mine seated properly, it never worked right. And, when I tried the wrong fitting, it would never seal. FWIW, the first pump that I tried, I could never get the "correct" fitting to work. Don't know why. I got tired of messing with it and got another one at the salvage yard and figured I'd used the first one for spare parts....
The fitting I'm using is loner than the stock fitting that cam out of the pump. It is the fitting that was in the list of parts necessary to connect the Explorer pump to the stock power steering box found somewhere else on this board (so it has worked for someone else.)
What fitting are you using?
Mine seals now and it puts out about half the pressure that my stock unit did. It's driveable on the road; but in the driveway it's a bear.
