Explorer rear disk - Parking Brake
vertex
Oregon City
I finally got around to installing my parking brake cables for my rear Explorer disk brakes. The problem I am having is that the parking brakes will not hold the Bronco. I apply the brake as far as it will go and put the truck in neutral and I can push the truck forward but it is locked solid when I try to push it in reverse. I tried adjusting them but it doesn't seem to help.
Anyone have any ideas.
gddyap
Mtn View, CA
Doesn't help you but I've never had satisfactory performance from my Explorer parking brake on my EB. It's been annoying because I've read of so many people who like it. I think the parking drums too small for my 35s. Probably work great if I had 31s. 35s just have too much leverage. If I ever move up to 37+ I'll have to come up with something else like a t-case brake.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
Talk to Saddleup. He claims to have broken part of his e-brake setup when he was running explorer discs and running 35s since the parking brake held so well.
mustangdave357
I have an explorer rear disc brake kit on my 9" in a mustang and was thinking of putting it on by bronco, what rotors would I have to use since the boltpattern is bigger? Thanks P.S. My rear e brake never worked well either, I just figured I hooked up the cables with too much slack or it just didnt work right with the mustang e brake handle.
vertex
vertex
Oregon City
I used the explorer rotors but had them re drilled with the Bronco bolt pattern. This is what everyone does with the explorer rear kit.
I do not understand why the e brake will hold solid as a rock when I try to push the bronco back but I am able to push the bronco forward with a little effort.
johnmlebel
because you have a little play moving foward with the brake adjuster where as when you move back the adjuster is locked in place its not much but it is enough
mustangdave357
Thanks, I thought about having the rotors redrilled but wasn't sure if that would be safe to do or not.
