Explorer Serp with Saginaw Pump mounted low.
NOTPRETTY
Folsom CA
If you could buy a brack/mount to allow for a Saginaw Pump to connect to an Explorer serpentine set up...and it mounted low...would you buy it?
Low mount equals easy management of a remote resevior
Currently no saginaw pump brackets available for the Explorer serp.
I am wondering how much demand there is for this...seems to be a narrow market, but maybe there's more than I'm thinking.
Post up if you'd want this.
FYI...In an ideal world this bracket would allow for an A/C compressor to. But, that may be asking too much in one area.
No
Saginaw is good, but not the only good pump. I would just run the Explorer pump that already fits the brackets without extra brackets and a pump to buy.
casadejohnson
Bronco Alchemist
I bet the market for it would be slim. I don't see how you would be able to fit an A/C compressor in there with the Saginaw mounted low, there is not a lot of room down there with the Explorer pump mounted high. Now if you had a bracket that accommodated the P/S pump and the Vintage Air A/C compressor, I bet you would find some takers. It would be nice to not have to use an adaptor for the Explorer A/C compressor to install a Vintage Air kit.
