I’ve been struggling with the power steering on my 73 build, and I need help!
1973 Bronco with 5.0L from a 2000 Ford Explorer. 4R70 trans, NP 205 Tcase
I have a new Borgerson steering box, and a stock Explorer pump. I just cannot get any PS action
So far, I have checked the hoses for correct pressure vs return. I even swapped them just for a quick start, so see if something would happen. Nothing…
I have the pressure line from the pump to the box, and the return routed from the steering box thru a cooler, and up to the reservoir.
I turned full turns left to right multiple times before starting, refilled fluid, and turned again while running
I replaced the new Borgerson box with another new Borgerson box
I replaced the pump
I replaced ithe pump again with a rebuilt Ford pump from the dealer.
I replaced the stock puller with a Driven Smaller pulley
I pulled the return line from the reservoir, stuck it in the top of the reservoir, started it and got flow through the return.
I ran the engine at 3000 RPM.
In every case, I got the exact same result. Nothing, not even an indication or growl that something was trying to happen.
Im lost for what to do next.
I need some guidance on where to go next. Any Help is appreciated!
I’d post a pic of my truck but I can’t figure out how
I replaced the pump
