Extended radius arms survey
trailpsycho
I will not get into what brand of extended radius arms, springs, etc. that I am considering as I am not interested in the posturing that sometimes ensues (XYZ are better than VHF, etc). I want to get a consensus on how much better the street-driving characteristics are with the extended arms. I already understand that there are significant articulation gains, which is great. Most of my driving will still be on the street, so I am looking to see how those of you who have extended arms like the streetability and ride on-road. If you dont mind, state what kind of arms and what you've noticed about ON-Road handling differences between stock arms. Anyone who has run a lift and then later gone to the extended arms on the same lift, I would really like to hear your thoughts.
I have a 2.5" lift now(Broncoparts of Sacramento) with double old school mounts; I took off the second set of shocks and the ride is much better...not so rigid. I like it, but would like to make the ride even better (Iknow-ditch the Rancho 5000s--will do). I want to put extended arms and switch to 3.5" springs for improved off-road-ability, but also to obtain a nice handling and smooth ride around town, so I just need some honest feedback to help me make a decision....Thanks for your time and attention.
John
SaddleUp
Vancouver, WA
Conflict:
"I will not get into what brand of extended radius arms, springs, etc. that I am considering as I am not interested in the posturing that sometimes ensues"
"state what kind of arms and what you've noticed about ON-Road handling differences between stock arms."
You need to decide which way you want it. While generally speaking the extended arms will all act similar it isn't a given that they will all perform the same. I.E. Some brands will perform differently than others which will have the greatest impact off road. On road the only difference most will have with stock arms is the extra built in castor that some have that will help it with driving in a straight line. Otherwise there is little difference on the road.
68 Broncoholic
WA
Stock radius arms will do just fine. What you need is the newer coils and shocks. This will be a huge difference on ride quality on and off road. If you have movey to spend, look into the Cage and Duff style extended arms. Otherwise why spend the cash on new arms if you don't wheel it that often?
trailpsycho
trailpsycho
Saddle up-
No conflict...I simply stated that I wasnt going to say which arms I am looking at to buy...however, I do want input from others on which arms they run and how they perform vs stock arms. I see no conflict. I want people to discuss extended VS stock arms and the experiences they've had with them, so it does become relevant which arms they run (built in castor or not, bent vs not, heim vs stud vs rod end). I have done searches, I understand the pos (ride and articulation) and negs ($$)...I am weighing the cost/benefit and figured this might give anyone with extended arms a chance to respond and not narrow the field to only one manufacturer and potentially make it a pissing match. Hope that helps.
swa0330
Portland,OR
I would say that if you can flex like this guys picture is, then you probably don't need to spend the money. ;D I know that in my talks with Jim at CAGE, that the concept that they and a few other susp kits have is to treat the whole thing as a system. SaddleUp has probably one of the more valuable opinions on this matter because I think that he drives his on the road a lot more than most people. One thing I can tell you, is that a lot of other things affect the ride when you have extended arms.
1) Running inboard rear shocks versus outside of the frame.
2) 1 versus 2 shocks in the front.
3) Progressive coils versus linear
The list could go on and on, but I think that the point is that you should maybe ask for responses of people who don't just have flexed out trailer queens. And for those that respond, what is the whole susp system that they have.
I can tell you only at this point everything that I have and why I chose it. I have ext arms, 3.5" progressive coils, and 3.5" Cage leafs, double shocks all around. I will be able to give you a better impression once I start driving in a few months. My talks and readings prior to choosing a lift kit were that I wanted to choose a system that was good on and off road. From my talks with a lot of people who drive on and off road (they wheel hard also) is that extended arms work well on the road.
Sorry for the babbling, but your question has a lot of variables to consider.
gddyap
Mtn View, CA
I run a wristed arm but I would think there would be more sway because the inherent anti-sway bar effect that a radius arm suspension has is reduced due to the added leverage of the longer arms. Is the increase in sway enough to be noticeable? I don't know but maybe someone has done some before and after testing.
Gil
bmc69
I'm running extended arms and BC 5.5" suspension. I have no issues with how it rides/handles on the road. I would say it certainly is softer all around and has more body roll than my previous rig but that is a lousy comparison because that one had a very 'old school' lift system; rode like a brick on and off road and 'flex' was not a term that even applied to it.
SaddleUp
Vancouver, WA
Gil
In theory yes this would be the case. In reality though the type of spring used in front has more effect on this. When I was running Superlift front springs my front flex was terrible even with the extended arms. They did make it more stable in corners but I would chip my teeth every time I hit a bump.
FWIW, I run custom extended arms that I built. (There are a couple of pics that show them below) They are 10" longer than stock with a bend in them for extra turning radius. I added some unknown amount of castor to them (Probably about 5 degrees). I still use the stock frame mount with poly bushings. One of these days I will likely replace the bushings with large rod ends to squeeze a little more articulation out of them. I'm not in a big hurry though as they do quite well already. Besides that I may decide to get a set of the Cage arms instead since they would be my first choice.
The remainder of my suspension consists of Cage 5 1/2" coils and Cage 3 1/2" rear leafs. In the rear I run a shackle flip to gain both the extra lift needed and to help with articulation. I have a traction bar in back as well so I don't bend another set of leaf springs. (I "S" shaped the last set) To keep the suspension tamed I run single Cage shocks at all 4 corners with the rear being inboard using a Cross Enterprises rear hoop. Something else I've done to make it stable on the road which I don't see mentioned above is that I have made the stance as wide as possible. My rims are about 11" wide with the beadlocks and the backspacing on the rims is 2 1/2". This change alone made a bigger difference in the way it feels while I'm driving it than any other. I do still get some body roll in the corners but not enough to make it feel like it's unstable. And yes, I do log a few street miles although none of them are between here and the trails. I.E. I trailer it out to the trails. I wouldn't call it a daily driver though because I don't drive anywhere daily.
gddyap
Mtn View, CA
I didn't think he was asking about springs. He seems to want to know what effect extended radius arms have on street handling. So everything else being equal, I would assume you could get more body roll/sway with extended arms. How much more will depend on other things.
SaddleUp
Vancouver, WA
I realize this however as was mentioned above the entire suspension acts as a unit where all of the components work together to the end result. My point is that beside themself adding extended arms will have very little effect on it simply because there is very little difference in bind in the stock suspension during normal driving on the street. I doubt that the difference would even be measurable and by itself it is not noticeable. Swapping the springs on the other hand will almost always result in a noticeable change even with the stock arms.
broncoswede61
Los Angeles,CA
The first characteristic that Cage lists is "smoother ride" on their long arms.If you assume that all the extended arms out there have the same benefits.....
I thinks it's a pretty simple question that trailpsycho is asking.Do they or don't they?
Projp
Stage one: Stock
What can I say?
Stage two: Duffs 3.5 springs, stock arms, 2 duffs 70/30 shocks
Smoother ride little more body roll
Stage three: Cage 3.5 springs, Cage arms, 1 bilstein shock
Even smoother ride and even more body roll
Impressions: I think the smoother ride has more to do with the springs than anything else. The cage springs were a lot softer than the Duffs, hence the smoother ride at the price of body roll.
With my combination it is hard to seperate what effect the arms had.
I am sure it smoothed things out, but it is hard to say how much.
I have toyed with the idea of building a street only halfcab DD. It would have stock arms, older Duffs 2.5 coils, Bilsteins, 5.0, AOD, A/C, cruise, electric dog polisher, etc.
76Broncofromhell
Bronco Totalitarian
Grass Valley, CA
If you aren't going to run a large lift and aren't going to wheel it, there is no point in extended arms.
The real benefits are flex, and improving caster. You will notice a little more leaning around turns. It's not unmanagable.
Spring rate has far more to do with "ride" quality than do suspension links. Shocks will make it roll a little less, but like Saddleup said before it's nice to have a matched suspension system. Mine is basically an orgy of parts, but it works as well as any $2000 suspension system out there.
73stallion
Eugene, OR
we used duff arms on jones' bronco with the duff 3.5" lift, and in addition we have a 2" body lift on it. it does ride impressively well for having dual shocks on each corner.
it has a noticable amount of body roll, but it handles great. i think these arms do well on the road. we haven't had the chance to really flex the suspension yet, but i tried it one night and i know it had a lot more than i put to it.
i tried flexing mine a few months ago, and it did a lot better in the rear than in the front. i'm sure a lot of it was because of the urethane bushings and stock arms. i can see where stock arms would limit travel. i also have progressive coils, i don't know if that helps or hurts me.
