I have installed the chevy disc conversion now about to tackle the extreme custom kit I bought last yr... which should i do over or under install? any links ? cant find ...
thanks
Here is one reference. This is well covered on this forum (as well as on Bfix)with lots of pics and anecdotes. I would recommend a search on " Chevy Tie Rod Over " or Chevy TRO ...make sure you have a big mug of coffee, soda or beer and be prepared to read alot. Lots and lots of info out there.
Personally, I would say go TRO with a axle riser bracket. Seems to be working out well for me and many others. Good luck.
This is the write up from my conversion. Its the same thing, I just sourced the parts locally. Going TRO was easy, especially since you'll have to do some reaming anyway. Made a big difference on my drag link angles.
I just finished a TRO steer kit . It works great , it was a good up grade . The only thing you have to tackle is you need to make or purchase track bar riser to put on your axle . Other than that it pretty straight forward .
Just make sure you keep drag link and your trac bar parallel with each other .
so i did tie rod over on the extreme kit, and now im tackling the trac bar bolt issue, on a 2.5 lift how much of a rise of the lower mount would /should i do? 2.5 ? would that bring it back to orig? or should i drill multiple holes for adjustment... OR just get the damn bolt out of the way of the tie rod and buy an adjustable trac bar ?
You probably wont be able to move the trac bar up much with a stock trac bar. get a adjustable one.
But you have you checked for clearance issues? You may be able to grind off the ends of both the tierod end and the trac bar bolt and gain the needed clearance.
I went to 3 1/2 SL on mine . I made my brackets, and ended up making an adjustable trac bar to help center body over the suspension . If you don't have a machine shop available you can buy everything off of JBG , or Wild Horse . I'm pretty sure the trac bracket that Wild Horse sells has a couple different bolt holes for height adjustment .
