Extreme Front Shock Hoops
Brand new never used, hoops are still bare metal. These were purchased from Wild Horses, link is below.
Here is the description from the website.
These hoops give you the advantage of dual front shocks while not interfering with other front end modifications such as the tie rod over the knuckle conversion and/or custom anti-sway bars.
Not only do the Extreme shock hoops look great but they are totally functional too. Wild Horses developed this style of shock hoop for the early Bronco because we wanted to take advantage of dual front shocks that would not interfere with other front end modifications such as the tie rod over the knuckle conversion and custom anti-sway bars. The Extreme hoops are made from 1.5" .120 wall steel tubing and they come with all necessary hardware and instructions. Welding is required for installation. Hoops can be painted as desired. The use of the front mounting position is optional for those who want to run three shocks per side.
NOTE: 76-77's require 2" body lift to use this hoop because of downward slope of driver's side inner fender well
Price is $250.00 per the Wild Horses website. I am asking $165.00 plus shipping.
If you have any questions, please let me know.
http://www.wildhorses4x4.com/product/Extreme_Front_Shock_Hoops
Thank you David
Thank you David
