F250 shock mount installation
doghauler
Western WA State
I’m currently installing my F250 shock mounts and I have a question regarding the cut/straightening process. I followed the directions in the Tech article, cut them and straightened them “a bit”, and welded the gaps. The overall change was that it moved the top mounting position about 1 inch (about 1 inch closer to the inner fender). Is this enough? I’ve read where some of you have straightened them completely. My body is currently off so I cannot accurately gauge the clearance to the inner fender.
Thanks.
73stallion
Eugene, OR
i've installed several sets, never cut and straighened any of them. never seemed to cause a problem for me. is there a specific reason why they should be straightened up?
doghauler
doghauler
Western WA State
As I understand, the F250 mount sits out a bit too far to allow for the shock to be vertical, it tilts out. In some cases I guess this may cause interference with larger tires during articulation and/or turning and the tire may rub the shock. As I am not an extreme 4 wheeler, I doubt it will ever occur for me, but I just wanted to check on the installation others had and how it worked. If you guys are both running with the “as is” configuration, it looks like I’ll be fine.
Thanks for the input.
rob wilson
Flagstaff, AZ
I didn't cut/straighten mine either. I did add some addtional material to the bottom of them so that I could extent them as high as possible. Didn't need the addtional room for my current shocks but you never know. IIRC I added about 3" to the bottoms.
00gyrhed
I read an article that said to cut and straighten them, but when I held them up to the frame after cutting off the old I saw that the shock angles were probably better than with them straighted and certainly better than using the stock length shock.
Forget the article and weld them on as is.
doghauler
doghauler
Western WA State
And I thought I was doing my homework! I searched on threads for mounting BEFORE I cut them and printed out the tech article as well. It sounds like it won't matter either way, so I guess I just got a few more minutes of practice on my welding....I'll post photos when I get them all done.
regshawn
Portland
O.K. I have a dumb question, so take it easy on me. What is the benefit of the F250 shock mount, is it any better then going with the hoops? Or does it accomplish the same thing but for a better price? I only plan on running one shock and just checking my options. Thanks
Shawn
regshawn
Portland
Sweat, I don't care if the hoops look cooler, this is a none show bronco, although I do like the cage ones. Thanks for the info, now I just need to research a little and pick some up. (sorry if I jacked the thread a little)
broncotime
Grapevine, Texas
When I did mine I extended them also so I could gain all the benfits of my 2 inch body lift. This allowed me to use 14 inch Bilsteins. As far as straightening them, I just clamped them into position and dropped a plumb line down to the radius arm to align them to vertical then welded them up. They've worked great for several years and tons of flex.
