Factory Roadster Door insert question
BajaBronco
Hey All, a Bronco buddy came to visit the other day and he and i came up with a question for the Roadster owners. He himself has had 4 or so and so have I , but this one stumped us. We were looking at an original roadster and the metal inserts that go in with the fiberglass pieces...the forward ones that go right by the dash seem to have no screws at the top two holes. In order to put screws in, you have to have dash out of the way somehow, and to do that youd have to have upper 1/4" dash bolt on either side out of the way or gone, which can't go back in unless you have forward metals off.....so which came first. Dash or metal inserts. I have a hypothesis, but I'd like to hear from the U13 Gurus, experts, 3-havers, and even one-havers, and even "a guy once told me"s.
mrdrnac
I just took my inserts off of my 66 U13 and both sides of mine were the same. No screws in the top two holes and you can tell there never was any thing screwed into the fresh looking holes.
Mrdrnac
BajaBronco
BajaBronco
Thank you for the quick reply. So far we are matching. This Roadster I have here is an Aug '65 build....so ...as with most things Bronco we may see some variance.
Broncoblood
I've taken a few apart and noticed that issue as well with BajaBronco on this Roadster.
Appears as if the parts were made to install that way but actual assembly posed a problem and went the easy route and or maybe the only route?!?
I guess were leaving them out : )
Check this out below;
according to the 1968 Bronco shop manual:
-DOOR INSERT PANELS
-REMOVAL:
4. Remove the five screws which secure the inside front panel to the front body pillar. Remove the inside front panel.
then for
-INSTALLATION:
7. Secure the inside front panel to the front body pillar with five self threading screws.
http://postimg.org/image/i5nuvbbmp/
TheBroncoRanch
Yes I had a very early production 66 roadster (friend in Canada now owns it) but same as you said they were probably skipped due to production issues. It had a amazing amount of bonding sealer to secure it on that bronco. I'm sure Tim could verify this also 😎
BajaBronco
BajaBronco
You might have one or more if.......You entered a drawing and YOU 1 THREE!
T-Bird
East TN
Bringing back this thread. I started today on getting my U13 changed to add the rear seat. I took out the bulkhead and also took off the door inserts to check out the condition underneath. I was really surprised at very little surface rust on the pillars and rockers. I too noticed the 2 screws missing on the top of the backing plates. Mine is a 2nd week of september build and the insert had Aug-26-1965 date stamped on it. It had the original springtime yellow underneath the inserts showing they had never been off even to repaint it green. They used 2 types of screws to hold these on...short pan head, and longer recessed screws. Can anyone tell me if the screws were painted along with the body or inserted after painting?
