Factory Tire Carrier Latch Doesn't Mount Flush
aredoubleyou
SF Bay Area
I purchased an original factory tire carrier from eBay and am doing some test fitting. I noticed that the latch assembly doesn't sit flush to the tailgate. The upper half of the latch assembly angles away from the tailgate by about a 1/4" or so. I'm wondering if this is normal or if I have one that has somehow bent out of shape over time. I'm worried that my tailgate will bend to accommodate the angle once tightened down (even with the backing plate). The pics below show a side view and a top view. Any thoughts from those who have, or have had, the factory tire carrier are appreciated!
Side view:
https://flic.kr/p/2sNiknL
Top view:
https://flic.kr/p/2sNhaVa
904Bronco
San Martin, CA
Original tail gate?
The latch will probably will distort the outer shell with the screws tightened to the plate inside the tailgate.
aredoubleyou
aredoubleyou
SF Bay Area
Yes, it's the original tailgate. Do other folks' latches follow the contours of the tailgate? Has the latch I have somehow "flattened" over time (excluding the hump in the middle)?
Oldtimer
Jr. Member with Sr. moments
Sunnyvale, CA
My latch matches the tailgate I have latch purchased from Ford in 70's, tailgate purchased in 80's.
aredoubleyou
aredoubleyou
SF Bay Area
Thanks for the pics @Oldtimer. Based on your pics and others I've seen, I think my latch is an aftermarket latch. The original latches seem to have a more rounded "bump" to accommodate the tailgate contours. Mine is more of a peaked angle. Also, mine has a cutout on the right side that shows the "bump's" angle more. The original ones don't have that cutout. Here are additional pics of mine which may be helpful to others:
Left side view:
https://flic.kr/p/2sNmSsB
Right side view that shows cutout:
https://flic.kr/p/2sNnU1n
