Fan fitment problems with serp setup
COBlu77
Arvada, CO
Here is a link to the radiator guard mentioned above:
BC Broncos Radiator Guard
Talk to BC about the minimum distance between the fan and radiator. It's been awhile but I remember Jason at BC telling me that 1" was about right and the fan should be half in and half out of the shroud. If the fan is getting much closer when you flex the suspension, you need to look for radiator support problems, engine mount issues, or frame issues.
Beware on those radiator guards, that if the fan touches it, it will rip it off and spin it destroying all kinds of stuff. They are held on with those cheesey plastic, zip tie like, things through your radiator core.
This is why I now own a BC radiator. Instead of a repairable nick in your radiator core, you'll have a completely destroyed radiator and whatever else is in the way when the fan starts spinning that radiator guard. My fan grabbed my cool looking radiator guard and completely trashed my radiator, belt, and shroud. My real problem was my core support was fatigued on the lower driver's side and twisting. I fixed that and all has been good. No more radiator guards for me.
Greg_B
Cohutta, GA
I run the stock 93 mustang engine and serp setup... I had to use a 1-1/2" spacer to clear the AC pump and it only left me with about 3/4" between stock radiator and fan. I have ran it this way for many years with no problem. I have thought about going to the explorer setup to get more room but the cost has prevented it.
As for the radiator guard, my company manufactured those for BC for a long time. Not sure who is making them now but if installed properly I do not see how a fan could rip it off. It is nothing but .156 wires in a circle with mounting tabs... the fan should just spin on the wire and only make a lot of noise if they make contact... I guess if the contact was strong enough something terrible could happen but then your radiator would be toast anyway. My biggest knock on the guard is the noise... it seems to whine when the engine revs and air rushes around the wires... sounds like I have a turbo charger on the engine. Must act like a stringed instrument...
I wish I had more clearance so I could remove the guard but I have been afraid to. All the solutions I have seen require cutting the core support which I do not want to do.
Greg
