Taurus Fan Fitment
lonicus
Costa Mesa
I know this issue has been beat to death about the electric fans...
has anyone been able to fit the Taurus fan in between a 4 core radiator and the water pump with a V belt without modifing the core support?
Here is the problem, I have the BCB A/C kit, so the condensor is taking up the room that could be used to mount the Rad forward, I can't use the stock mech fan because it interferes with the compressor, the low profile flex-a-lite fan I have dosent push enough air at idle to keep the engine cool (at speed there is no cooling problem) so I can't move the radiator - obviously can't move the engine, and need more air movement thru the radiator.
Do I need to just buck up and buy a super low profile electric fan? I already got the Taurus fan...
fungus
Kaneohe Bay, Oahu
Ain't no way, no how you can fit that Taurus fan in there w/ V-belts and stock core support! I've seen it fit w/ a stock CS/ 3 core rad and an explorer serpentine setup and it was within 1/2" of the wp shaft. Sounds like you might be looking at a dual fan setup, thin electric puller and electric pusher in front... Just had to have that A/C didn't you... LOL!
Can you run a different spacer on your mech fan to clear the compressor and still not eat the rad?
Justafordguy
I just went through this same issue. After several weeks of bracket mods/etc I was able to get the stock fixed fan to fit without hitting the compressor. I have a 3 core aluminum rad but I think the 4 core would fit. I still have about 1.5 inches between the fan and rad. Basically I had to move the compressor mount out further from the center so it would clear the fan. The compressor pulley is now just outside the shroud and back towards the engine a little. I was only able to get one belt to line up but it only slips a little when I first start it up.
lonicus
lonicus
Costa Mesa
Dammit.
I thought so, I have 2 smaller 12 inch low profile electric fans, not enough room in front to make a pusher, but perhaps used in a dual setup as pullers? I just hear they dont really flow that much air.
Plus I would have to take one from the '66 mustang - but the flex-a-lite might work well there, it's a small I6 so dosent need the cooling capacity of the bronco - plus it never gets driven...
Wish I hadn't blown the cash on the fan.. oh well
lonicus
lonicus
Costa Mesa
Mine slips too, in the "original" location. not really enough belt area on the compressor. Havent been able to figgure out how to fix that...
