I'm getting a little conflicting info from the vendors about if a stock OE style fan shroud will work with my 1" body lift or not?
Anyone have an actual answer?
No, Hack saw, file, cordless drill.
Upper plate:
Cut to length, to fit between radiator mounts.
Trim to match contour.
Trace holes from radiator to plate, drill to match.
Drill two more holes 1" lower.
Bolt in.
Repeat for lower plate.
I just notched the bottom of my fan shroud where it interfered and left it mounted in the stock location. No issues in the last 10 years with running hot.
