Fibermetal build thread
M
Miker
stay the hell away from mine when it's done....good lord! chrome booster? really? %)
Randy, I just won a million dollars! I figured once you saw the blingy booster pic you'd be a rebel rouser,,,,,
M
Miker
Looks great Mike! I would love to see it in person so my offer still stands..... On your way back from Florida stop by for dinner. I'm literally 3-4 minutes off 95.
Might be a while Allen, but, bank on it!
M
Miker
WH Transfer cover plate
Got the WH transfer cover plate installed, I like the look and I think the bolts used look pretty skippy as well.
dave67fd
Mike, Don't know how my dumbass missed your build up to this point but your doing a great job. Awesome rig. Love the detail. Keep up the good work and the pace.
tasker
all knowing of nothing
NH
dave, find an ebrake pad on your bench after we left?
dave67fd
You know, funny you mention. I saw it there while you guys were there and it threw me off abit. I have a new pad i bought for the Fairlane and thought it was that but didn't ever remember having it out. Then i thought someone may have brought it for someone else. Forgot about it since. Haven't even gone out to clean up really. Was planning on today.
So were you the bearer?
Ohh and forgot to give you that ash tray. Don't know if you still need it.
M
Miker
Had to go with two holes up top to help secure the pedal assembly. Good news is that Ryan said the maker of this tub laid a 1/8th sheet of steel in the glass and that should also help provide some strength.
M
Miker
Ryan found a piece of aluminum that was laying around that was a perfect width for the brake bracket.
M
Miker
Ok, some progress to report to you all. MSD box mounted, shocks I had laying around installed, WH billet brake and gas pedals installed,drop bar bracket welded on,
M
Miker
A little more progress. welded nuts to the windshield frame then ran bolts through the tub to secure the windshield. Button head stainless bolts for the brake assembly, doesn't look bad I think.
dube
big lake Mn
miker, the tab on the fender in front will need to be bend it up 90* so your outer fender will bolt on.
nice build.
M
Miker
Some updates, fabbed up a bracket that has an angle to it for the throttle cable to work and clear properly, found a thick grommet to be able to run wires through the firewall, installed the throttle cable and cut the MSD wires to size and soldered for box to dizzy.
M
Miker
both Lokar throttle and kickdown cables installed.
M
Miker
Got the radiator intalled. It is tight, but with the serp setup it will be okay. Also got the battery installed.
tasker
NH
wow, beautiful Mike....can't wait to see it
M
Miker
Thanks Randy, I appreciate the compliments. It can't get here soon enough for me but still lots to do.... But, continual forward progress being made.
You started back on yours after inspiration from Super Cel.?
