Finally home and digging for treasure!
Spartan
Backwoods, KS
Well, I've just recently (starting last week) been able to get back here (iPhone decided to take a dive and AT&T/apple take forever)
But basically was able to finally get my 77 bronco, completely, home (first time I could only grab the interior, trim, lenses, keys, title, etc etc i had my car dolly and I didn't feel safe hauling my EB that way so I was able to replace the hub on my trailer) long story long-
Anyway, so this 77 is a PS, PB (disc brakes up front), 302, Dana 30 front, 9" rear, 3spd on the tree model, I guess it's a HD? I keep finding 4900 gvw everywhere (U15GLX)
But I found out I'm the 5th owner, gauge shows less than 50k miles (or maybe 150k?) this EB spent along time in storage when one owner pulled the entire interior and had it all redone at an upholstery shop so it's all brand new still, and its redone in saddle or parchment.
Overall the truck is in good condition, looks like ill be replacing the passenger side fender, maybe the hood(?) found a dab of body filler on the top front (?) and maybe a grill once I sand down the bottom front edge and figure out why body filler was put there (?)
But good news, I found a TON of original paperwork in the glove box including;
Bill of sale receipt from Hammond Motors Ford in LA on 1-21-77 and this EB $6160 with 6 miles on the odo.
Even found the orig BF Goodrich tire brochure etc
Id say at some point it had a lift kit installed since its wearing 31" tires now and looks like plenty of room for more rubber since the fenders were cut. I'm not a fan of the front bumper though or the camo and white paint.
Ill need to replace the drivers and passenger foot well area and the back bed area at each corner, the top looks great and the original white paint is still shiny inside, but the top is going bye-bye.
rustbucket
Looks good! How about some interior shots? Btw, you should have a Dana 44 in front, not a 30.
NGABronco
Always Learning
N. GA now South Carolina
Hey Congrats, that thing will buff out!!! Being a 77' that might be a Dana 44 front end??? Now get to work!!!!;D;D;D
Aw, rustbucket, you beat me to it!!!!
Spartan
Spartan
Backwoods, KS
Thanks guys, I'm pretty excited!
I'm not sure what the axle in front is, I've been decoding but the #'s get confusing at times, guess ill just have to take a peek-
I have the new interior tucked away in the house-away from sharp, pointy, dirty things lol
I was told it will start right up and run like a champ, the oil looks used but not filthy black, all the fluids are up to level and the motor does turn over by hand it also looks to be an electronic ignition, so once primed and the tanks cleaned, she might crank to life.
JohnnyB77
Amarillo, TX
Unless someone sneaked a Dana 30 with disc breaks under there its a 44.
Ford started using them in 71 but disc breaks were not added untill 76.
DSO is New Orleans
Color code is probably Hatteras Green Metalic
Spartan
Spartan
Backwoods, KS
DSO is New Orleans
Hey Johnny,
its probably a D44 then, the color codes have me confused slightly on the VIN decode websites, I keep coming up with 2 different green colors and interior/exterior colors depending on which website I look at. Ill do some more decoding and try to figure it out.
Spartan
Spartan
Backwoods, KS
Johnny you are correct-
I looked around under the front end tonite and the axle has a single large nut on the knuckle (I had a 73 dodge power wagon with a D44 front axle and it used the same set-up)
surfer-b
You got a $100 of scrap steel in bumpers, these old Broncos always seem to have some of the most crazy bumpers on them
