Fire suppression systems
Johnnyb
Flagstaff
I was wondering if anyone had installed a system like this: https://www.summitracing.com/parts/...HnAvnI_Q_n2lzApIN-i8c5JHFiRzobLkaAteNEALw_wcB
In their EB?
While I was very careful with my fuel system, tales like this one: https://classicbroncos.com/forums/threads/post-fire-rebuild-starts-now.330254/#post-3629442 make me wonder. With EFI pressure at 40+ PSI, one loose fitting or fatigued line, and you have a fire!
Remote release with strategic nozzle placement would be a nice reassurance!
-JB
Grey owl
they are a good idea and even mandatory for some race cars. For a fuel injected street car i would use a fuel shut off switch.
Johnnyb
Johnnyb
Flagstaff
For sure a shut off switch, however there's enough fuel in the rails, lines, and regulator to cause some significant damage even with the fuel shut off.
904Bronco
San Martin, CA
Annually and post open track events my Shelby gets on the lift and I completely go over it looking for issues... How many Bronco owners do you think do this? Things wear out, fuel lines have a certain life span.
Yes, random things can happen, Murphy's law can be in effect, even with the utmost care and preparation.
Most fire suppression systems need to be checked regularly, tested, certified, tanks hydro tested, etc. Piece of mind, yes. But you need to factor in the required maintenance as well in the overall cost. "Blazecutusa" has a 10 year lifespan, and you should be checking the gauge every time you get into the rig.
Carrying extinguisher(s) is an excellent idea, but they should be serviceable, and have annual servicing. And be well secured. Checking the gauge is only part of the maintenance, sitting upright, being bounced around causes the powder to settle and clump at the bottom. I once used a large dry chem unit off the fire engine that once pressurized, the only thing that came out was the propellant gas.
So I guess what I am saying that for piece of mind, these fire extinguishing devices, will need maintenance just like the rest of the Bronco.
Johnnyb
Johnnyb
Flagstaff
Maintenance is a given as is checking the gauge. I carry three mounted ABC dry chemical extinguishers, one at each door and one at the tailgate. The system I was looking at uses Aqueous Film-Forming Foam (AFFF) and the attraction is being able to discharge without opening the hood. This is not a track vehicle and never going to be inspected for an event, so it is just my piece of mind and pocketbook to worry about.
-JB
ntsqd
heratic car camper
Upper SoKA
I am wary of a system that uses polymer tubing like the Summit link above. The various sanctioning bodies that I have raced under don't allow it. They want a metal tube because it can't melt nearly as easily in a fire. Most racers use aluminum and that's the accepted tubing most everywhere. If the aluminum tubing melts, you probably weren't going to save the truck anyway. Hopefully it'll give you enough time to get everyone out.
Remember that 37° flaring tool? Yeah, most systems made for metal tubing use "AN" fitting geometry.
The point made about regular inspection is true for all of the systems in a specialty use vehicle. Our DD's tend to spoil us with their competency. Special uses usually means that you're working the vehicle harder than you work your DD, and that means that race vehicle or not it should get the same level of care that race cars get.
A hand-held extinguisher that I'm about to deploy in my DD is this: https://elementfire.com/ I'll still have a dry powder in the vehicle, this is in addition to that.
And FWIW I lay my dry chems on their side and then periodically roll them over 180° them so that the powder doesn't get too compacted.
Yeller
Rogers County Oklahoma
inspectors turn them upside down and smack them with a non marking dead blow. Some get a little carried away, you know they did it because its dented lol.
ntsqd
heratic car camper
Upper SoKA
That's how my friend describes riding in a desert race truck or buggy. Only it isn't quick even in a Trophy Truck or Class 1.
For a fire extinguisher that might work.
ssray
South Central NE
For those really worried about when parked need a fire sprinkler system in the garage. There’s some really cool systems out there now that don’t flood everything and do an excellent job, think industrial fog machine, Aquarius suppression systems
All I get is Plumis Automist so maybe they've been bought out. Pretty high tech system with that wall mount nozzle that finds the fire and the low volume water needs. Good illustration of the kitchen fire. Would be good for a garage with flammables, but I am curious how well it would work with a fire contained in the engine compartment or interior though I don't know how common fires are in vehicles not in use.
