FireBronco Build Pics (4-link pics added)
Madgyver
Madgyver
Bronco Madman
Peanut......
Madgyver
Madgyver
Bronco Madman
4-link pics
Modified an older 5.5" link kit to work with our planned 3" lift..
Cut a notch in rear crossmember and also cut 23 gallon tank for clearance as rear axle is moved back 4.5"
Madgyver
Madgyver
Bronco Madman
More 4-link pics
Madgyver
Madgyver
Bronco Madman
4-link pics 3
Madgyver
Madgyver
Bronco Madman
4-link pics 4
sprdv1
REBEL
back to the top... I realllllly need to come over there and go for a ride wit ya haha
maybe when all this mess is done
Madgyver
Madgyver
Bronco Madman
i'll just add more pics here....
Madgyver
Madgyver
Bronco Madman
Mad nice job on the cover! What is that black brush on "paint" that you put on everything? Is it a magic rust killer;D
Thanks Ben,
it is PPG Amerlock2 + Cure (catalyst). It is my go to product for rust protection. Floor pans for sure. Under the tub. Everything that we will get exposed to our salty environment which is every thing. It is easy to touch up if needed. I will choose this over all the liners out there but that's me. Cost will be about $200.+ for a gallon of each, paint and hardener which will yield about 2 gallons worth.
You'll need to wear gloves when painting because it will stain your skin for a few weeks. I have thought of spraying it but you will have to sacrifice your spray gun each time you spray it. I will usually mix only a cup total at a time and that is a lot for covering an area and you will not waste any due to it hardening up.
Madgyver
Madgyver
Bronco Madman
Mad, is that UV stable? I’ve been looking at different products for painting trailers.
I know that they use this on the boat docks so I assume that it is. It does fade after a year but it still protects. I would use it on boat trailers, I recommend it to all my customers that I've built racks for.
Madgyver
Madgyver
Bronco Madman
Random pics
