chrisd0729
Anyone know what this is called or where to find it? Looking for the rubber grommet that seals the firewall hole where the power brake rod goes through (circled in the pic below).
The boot is in the cab.Hey Everyone,
This forum is great! I didn't think it would be this painless to find the part number for the boot/grommet.
Thanks Stoker for providing a part number for JBG!
I do have a question about the install. Will this install from the engine compartment into the cab by disconnecting the rod assembly inside the engine compartment and sliding the boot over the fork on the rod? Is there enough give in that opening to allow for that? (It sure would have been great to have installed correctly when it was in the shop.)
Thanks,
Jeff
I would either weld it or bond it with JB weld it. Otherwise I think I would drill it and pin it as Dirtdonk said.Yes, by dimple I meant just that.
Even still, that does look like an awfully small set screw for such an important and robust duty.
The amount of pressure that can sometimes be applied by a leg during a panic stop must be very serious.
I wonder if through-drilling and pinning would be better.
And even here, it seems like more than one would be a best practice.
Hence, my thoughts on welding…
