First drive in Colorado Springs....Gold Camp Road
cmc
Nice drive this morning in the Bronco, enjoyed the road time and great views in Colorado Springs.....thought I might need some adjustments due to the altitude, but so far no problems. Holley truck avenger carb is working great....hopefully will continue at higher elevations. :)
Scoop
Have Bronco, Will Travel
Cuchara, CO
My Bronco is broke down and is still in CO. Going to try to bring it back to Texas in December for the winter . . . that said, if you have moved to the Springs long term then chances are EFI will be in your future. This particular Bronco when sporting a carb would not run above about 11,000 ft and started running poorly above about 8,000 ft. This was with a stock 2150 carb - your Holley may work better. With EFI it runs great even over Imogene Pass at 12,800 ft!
jckkys
I've run a carbureted Bronco to the top of Mt. Evans 14,271ft. with no problems. This was a truck sold in Denver. So some high altitude calibration was done at the factory. Anyone with a little skill can do the same. EBs are classics that weren't made with EFI. Mine will stay that way and that's no problem. Ford 2100, 2150, and 4100s are a lot better than Holleys and don't need much to work well over a range of altitudes.
Colorado Springs
You’re totally right. I de-tuned the carb for the altitude (5,500 ft) when I got here. I went up to gold camp this weekend which was another 5,000 ft. I was definitely struggling but luckily made it back down.
74BroncoCO
Been on that road many a time! It can be treacherous in the winter, but that was part of the appeal. Just be careful up there. Some crazy people do stupid things up there.
