eds66bronco
Well, had to do it. took the bronco for it's first road tip to my father in-laws to check things out since the engine/tranny/brake system upgrades (5.0 sefi from a crown vic, np435 and hydroboost with rear disk.)
started out running a bit rough so i took it easy. figured i'd give the computer some time to relearn. got going and noticed a lack of power under load - bogging at the upper end of second gear and no power in 3 or 4. as i got near my in-laws i noticed the temp guage not working?? i pull in to the drive and pop the hood to find coolant had sprayed out the cap and the overflow resevoir was empty ?:? wire had popped off the temp guage so i put it back on and checked the temp -185º i feel the rad and the hose from the thermostat housing to rad is hot but the drivers side tank is almost cool to the touch so i shut it off.
let things cool a bit to check radiator level and it is about 2 inches low. father in-law says lets check the flow in the radiator with the cap off so i turn it over and we watch the coolant - not much flow and again, the lower hose and driver side tank are cool to the touch. we watch as the coolant level slowly rises and i shut it off before the level reaches the top so i don't loose more coolant. the second the engine stops, the radiator goes old faithful on us and shoots a gallon geyser out the hole!
i now assume i have a bad water pump??? we pulled the brand new t-stat and tested it with a thermo gun in a pan of water and it is good.
filled it all back up with water and same thing again with the cool rad on the drivers side and hot on the pass side (brand new ron davis rad-so i know it's not that) we also found 3 injectors are not even firing
HELP!!
HELP!!
