FiTech Hy-Fuel pump
Moon's74
Henderson, NV
I'm putting together my EFI conversion from a 98' mountaineer. I have TBP 23 gal fuel tank, carb, and would like to keep it if I can.
I've found a lot of threads here about EFI pumps both in and out of the tank but none touch on the FiTech Hy-Fuel retrofit pump kit. I know it's a little pricey but it's still half the cost of a new tank with all the goodies installed and looks pretty easy to install for the Mountaineer EFI system w/return lines.
Anybody have any experience with it or a similar install? I'm definitely looking to go with an in tank system and this one looks pretty simple.
needsmoarturbo
I realize this post is months out of date, but in the interest of providing hopefully useful data to others in the future... I found your post trying to search for info on the same setup, with not much info coming up on here. Did you end up going with it?
The only comment I have on the setup you were specifically looking at is if the "hat" part that mounts to the top of the tank looks like it might be taller than the spacers that most of the 23 gallon tanks have on top to keep the sending units off the floor of the truck... So you might need to put taller spacers. Hard to say without finding the exact dimensions. Another option that looks promising is their fitech "g surge" kits that just mount in the engine bay and you run your low pressure pump into it, it has a float just like a carb and it basically holds a quart of fuel or so and a fuel pump so it can boost the pressure up to what is required for EFI without having to mess with changing out the fuel tank or a lot of fuel lines, just run your low pressure into it instead of a carburator.
omureebe
So I have the Hy Fuel retrofit pump (without regulator since I have the FiTech), and waiting for my 68 to come back from the body shop to get this pump and stock tank in. The "hat" sticks up about 3/4", so with my 1" body mount there appears to be room for it to fit. I'll really know in a few weeks when I do the install.
The issue I see is if you keep the factory tank discharge (as I was planning, as a back up and to keep the fuel gauge operational), that sticks all the way through the middle of the tank. So where do you cut the hole to drop in the pump? Only idea I have is to put it on one side of the tank.
More to come...
I don't think that's a problem on a stock tank because there are no real baffles of any substance that I remember. I could be wrong, and maybe different years had variations, but pretty sure the stock tank is just that. One wide open tank.
Which means that as far as the components go, you could put them pretty much anywhere they'll fit.
bronconut73
That FITECH fuel command center has had a few issues. Well documented here. I was glad to see FITECH and Holley have their in-tank set up pretty "dialed-in"
