Flashing headlights? amp meter vs volt meter?
70greenhorn
Manakin Sabot, VA
On my trail rig, the headlights and marker lights are surging/flashing at idle. they will flash faster as the rpms increase to 2500-3000 and then they stop flashing. The PO installed an amp meter rather than a volt meter and the meter will jump in good time with the light flash.
I thought the alternator might not be charging so I checked the belt...It was way loose so I tightened it. I ran the truck and the flashing/jumping amp meter cleared up and ran smooth.
the rig sat for a week and when I started the truck last weekend, the flashing returned. I checked the belt...tight, I checked the battery volts (engine off) and compared it to engine volts while running and it appears the alternator is doing its job.
I am electricaly challenged and don't know what to check next. Can you guys lend some advice on what to check and how to go about doing it?
also, what is the amp meter telling me and why would it be installed rather than a volt meter?
Thanks in advance,
Travis
El Kabong
Driving stuff Henry built
An ammeter measures electrical usage, usually in the form of amps plus or minus. It shows if the alternator is charging more than the vehicle is using. Basically it tells you if the battery is being charged or discharged at the point when you look at the gauge.
An ammeter doesn't tell you if the battery is holding that charge. It doesn't tell you if the average over time is a gain or loss. It is also limited to the max amps that it will read. So if you have large draw items (Starter, winch, etc.), they are not run thru that gauge, so you don't get the whole story. Wire sizes to the gauge need to be big enough to carry the load for all the items run thru the gauge. You only get info on the items that are run thru the ammeter.
A voltmeter measures the overall electrical status, the current voltage available. It measures the difference between positive & negative sides of the battery. It doesn't exactly show if you're charging or discharging, but you can figure it out by the voltage shown. It only takes enough current for the gauge itself to get that reading, so wire sizes can be much smaller.
A voltmeter measures the effect that everything electrical on the vehicle is having on the battery, & how it has been affected over time, so it is more of a complete picture than an ammeter can give.
Older vehicles with very little voltage draw came with ammeters. Modern vehicles with lots of electrical items have gone to voltmeters. I've run both types, & like the precise gain or loss info from the ammeter, but if I had to choose only one, it'd be a voltmeter.
70_Steve
Old Guy
If you could also describe the flashing as a flicker (very fast) then I'd say the culpret is probably the stock style electromechanical (relay)voltage regulator. These regulators can only either put full voltage on the coils in the alternator or nothing. So, you get the voltage jumping around and you see it in the headlights.
Try a solid state voltage regulator. The application that always comes to mind is a 79 Granada... :p
Scoop
Bronco Old Fart
Cuchara, CO
Best fix is a headlight relay harness especially if your running halogen or upgraded headlights. Should fix the headlight flashing and will give you MUCH brighter lights.
Although it does seem weird that the marker lights are flashing too.
I don't agree with the light switch or relay setup as a solution to this problem. They are both good fixes for their respective issues, but from your description you don't have an overloaded or failing switch, but a surge in the battery/charging system.
I've had the light switch issue, and when the internal circuit breaker inside the headlight switch has had too much, it literally turns the headlights off. When it cools, they come back on. Sometimes this takes a second or two, sometimes it can be a minute or more. Most often it's just a few seconds at a time, but the lights quite clearly turn on and off. What it sounds like yours are doing is flickering, and the ammeter is pulsing. With a bad light switch, the ammeter would flicker as the load changes, but it would not pulse to the plus and minus ranges like it sounds like yours is doing.
The pulsing charge is caused by either the defective regulator (most often) as already mentioned, or a defective alternator (less often, but still an issue), or a faulty connection somewhere in between the two.
If you read every thread on this subject, you'd find out that there seems to be no one fix. For some, simply replacing the regulator works wonders. For others, going through the entire charging system one piece at a time doesn't quite fix it. For still others, fixing/replacing all the main ground wires reduces it to just a hint of it's former glory.
And then there are the cases where the old ammeter has dampened it's last, and the needle is going to fluctuate no matter what you do.
First thing I'd do then, is to check all the wires and connections, clean the alternator's mounts with the engine block, verify that the ground wire between the alternator and the regulator is still intact, and make sure you have a good negative battery cable running from the battery to the engine, from the battery to the body (fender), and, for good measure, a strap from the engine to the body (firewall).
Next, since they're relatively cheap, I'd just replace the voltage regulator with a modern integrated-circuit type.
I'm not sure how to test the alternator for some bad diodes or rectifiers or whatevers, but I don't think that the standard tests usually performed at the local auto parts stores are going to show a pulsing output. I could be wrong on that though, and maybe someone else knows for sure if the standard tests are enough.
When alternators were 15 bucks, it was easy enough to just throw a new one on there. But that's not the case anymore, so see if someone can test yours.
Good luck. That headlight relay setup mentioned before is one of the slickest improvements you can do to a Bronco (right behind disc brakes!), but I don't think that's your problem. When it temporarily went away after tightening the belt, it seemed to indicate a charging issue.
If your lights are actually going on and off though, instead of pulsing, then that might just fix your problem after all.
70greenhorn
70greenhorn
Manakin Sabot, VA
ALL,
thanks for the great responses. I really appreciate your help.
I was thinking it may be more of a charging issue b/c the amp meter will jump with out the lights on too (it seems to jump more when lights are on though). Also, all the lights will surge...even the dash lights.
It makes sense to check all of the wiring, grounds, etc...I should have done that before posting.
Where is the voltage regulator located? and when I go to NAPA and ask for an integrated circuit type, what vehicle has the newer regulator that I will need?
thanks,
Travis
I would think by now that 90% of the units you get when you order one are going to be the more modern type. I mentioned the difference though, just in case someone is still selling the original points-type replacements.
You used to be able to tell the difference in the height of the "can". Where the old type was about two inches tall, while the newer type might be an inch.
You can either specify your year Bronco, and just tell them you want the modern electronic type, or specify a '78 Granada or something like that. That's what a lot of members here have specified.
I'm not sure why that makes such a difference, but perhaps that was the first year they came as original equipment? Dunno, but the guy behind the counter might actually know too. So ask.
Your original one would be the squarish metal topped "box" mounted either to the inner fender wall, or inner fender well, just adjacent to the battery, or on the firewall above the heater hoses on later models.
If this is a '70, I'm thinking it's on the inner wall, mounted vertically just behind the battery. It'll have a 4-wire plug with an Orange (F), Green w/red (S) and one or two Yellow (A) wires attached to it.
Make sure you have the new unit fully bolted to the body (with the small black wire under one screw) before you plug in the connector.
Paul.
70greenhorn
70greenhorn
Manakin Sabot, VA
Hey Paul,
Thanks for all the help man! I will gather some parts and try to work on it this weekend. I have to install inner axle seals before we go to the Round up at Gore next weekend. Hopefully I can get to the regulator/light issue addressed before we go..
Thanks again for your help...I will let you know how it goes.
Travis
