flexin it up
huged29
Ft Collins, Colorado
Sorry no pics, but I finally got to test out all of my upgrades and I am really happy. Went up a 3 foot high rock forward and backward with open diffs and didn't even lift a tire. The thought I might have to change my shock lenght on all four corners but everything worked perfectly and I still had an inch on the compressed sides. Now I can't wait to hit the trails for the first time in almost 2 years. If you want to see what I am running it is in the bottom of all of my posts.
Mr Joe
Do you have a pic of your rear shock mounts? What shocks are you running in the rear?
huged29
huged29
I am running the cross enterprises rear hoop with some shitty rancho 5000s that have 10" of travel. I thought that they might be too long, but after flexing it out I still had about an inch left and the springs were starting to go inverted.
Mr Joe
Thanks, Guess I'll get the 10" shocks too...;D
huged29
huged29
You might want to go a little shorter if you don't have a body lift. When I mounted my inboard hoop I welded it higher on the frame because I had extra space from my 2" body lift. If you have to mount it lower on the frame you might want to use an 8" or 9" travel shock.
Mr Joe
I have a body lift, but didn't take it all the way up. I wanted to keep the mounting plates on the frame. My kit came with 12" shocks shown here.
huged29
huged29
I think 10s will work good with your setup. I was not even close to extending my 10s out all the way. Just make sure to measure your bump stops carefully or you could take out a shock or the whole hoop if you hit it hard enough.
