Airmapper
Foolproofness Tester
Well it's always worse than it looks. I've kinda hit a wall here.
I started a 1" body lift. I started on the passenger side, and while it's slow going I've been having good luck removing them.
But on the front the PO so generously patched the floor pans by putting plates on top. (actually I found 2 layers of patching.) That means I had to get under there to find the body mount bolts. So it started as a body lift and before I knew it, I had most of the seats out, pulled my roll bar that was sitting on imagination, and had the patch panels off on the passenger side. (The drivers side are chicken shit welded in...)
I am a little overwhelmed with what I found. The floor pans themselves aren't such a horrible problem, still more than I can tackle right now, but at least I understand what to do. My worry is the under floor supports are about gone as well. Especially the ones under the front floor pans. The others aren't great, but are better.
I'm trying to build a trail rig. I'm not worried about factory restoration, if I'm able to fix this (emphasis on the IF) I'm just looking for functional and secure.
My questions:
Can this be fixed without removing the tub?
What are the minimum requirements for equipment? (Welder, sheet metal tools, etc....)
I plan on having non stock seats and possibly other mods. My NP435 hacks the tunnel cover as well. Is it worthwhile to use OEM style replacements, or fab stuff? Maybe buy a few of the replacement channel supports and use sheet metal for floors?
Any advice on what options I have, what route I can take, and how much work this is to fix would be appreciated. I was really wanting to get a cage in soon but this kinda has me worried that will be pointless if there is nothing under it of any substance.
My questions:
