casadejohnson
Bronco Alchemist
- Jan 21, 2005
- 3,587
I'm doing the floor pans on my 66 this weekend and have a question about the drivers side. The original pans were removed by a previous owner and replaced them with some homemade ones riveted and screwed in with about a a quart of silicone in between. I pulled the driver side out today and it appears that the upper portion, behind the pedals, is completely solid. I'm thinking of leaving the upper solid portion and replacing only the portion that has already been removed. By doing this, I'll avoid messing with the E brake floor bracket. I would cut it similar to the way the pans that Wild Horses are made. Any reason not to do this? The floors will be covered with bedlliner and carpet so the aesthetics are not a big concern. Here are some photos of the WH pans I was talking about.
I'll get some photos of the PO's work and get them posted as well.
