Floor pan support channels galvanized ? Welding question
Tonyduc
On my 66 I am going to replace the drivers and passenger floor panels with new ones I got from Bronco Hut. Was going to use sheet metal screws then replace with welds one by one as discussed in previous posts on this site.
I am a beginner welder here and just read that welding on galvanized metal is something to avoid as it creates toxic fumes:
https://www.instructables.com/id/How-to-Weld---MIG-Welding/
So the question is are the floor support channels galvanized? They do seem to have some kind of treatment from the factory. If they are, I might try sheet metal screws + epoxy (like JB Weld), this has also been discussed here but not sure of the long terms results.
Tony
bronkenn
Bronco Guy
Southeast Ohio
Yes they are galvanized and you can weld them, just make sure and have plenty of ventilation or a respirator. A few of the parts you get from venders will be galvanized as well. Just be careful and you'll have no problem.
rjrobin2002
I have been welding them for 20 years. I just turn a fan on low to create a breeze to carry the smoke away and I dont have my face right over the weld and kinda position myself to the side.
Redbark
Another option is to grind off the zinc on the floor channel flange and coat with weld through primer.
I'm new to welding also. I just finished my floor panels and found that filling screw holes alone did not provide nearly enough penetration to hold the panels together. I pre-drilled 5/16 holes at the same spacing as the spot welds along the edge of the floor pans, fitted and secured with the screws and plug welded the 5/16 holes to the sheetmetal overlapped underneath. Then I removed all the screws and welded those holes closed top and bottom. It's extra work but the welds are good and solid.
ShoeSlinger
I have always welded mine but I would not be opposed to using something like 3M 08115 Panel Bonding Adhesive on the floor channel. I have seen many welded incorrectly that did not hold. I weld mine from the top and then usually put it on the rotisserie and weld on the bottom side too in order to make sure they are secure.
T
Tonyduc
Thanks to all for the advice. I have seen other posts that mention in the new panel to drill a hole larger than the one in the channel (for the screw) to make a plug type weld as Redbark mentions.
sykanr0ng
On a welding forum I asked about galvanized and welding or cutting, the fumes do not seem to cause long term problems but you will be miserable for a day or two if you breathe them.
