Floor panels and Rockers
Ches7911
OKlahoma
I am trying to determine if I can cut out the old and weld in new floor panels on the driver and passenger side without removing the body from the frame? I will also be removing the old rockers (inner and outer). Maybe I should do this in a particular order? I do not have much room or storage for my project so I am tackling it pieces at a time. I cannot really pull the body off the frame...thanks for your input.
Mark
Bronco Klutz
NW Indiana
You do not need to remove the body from the frame to replace floor pans.
The rockers are bad also?
Ches7911
Ches7911
OKlahoma
Yeah, the rocker panels are in desperate need of replacement. I just didn't know whether to replace them first or the panels first...
Thanks for the posts fellas.
Mill KNOB
Rock Hill, SC
You can replace which ever one you want to first. Just make sure that your kick panel does not need to be replace. Because the new floor pans weld to the kick panel. Why you have the floors out and the kick panels need to replaced then that is the best time to do it. Just my two cents....
Ches7911
Ches7911
OKlahoma
Thanks Mill! I think I am going to be safe on the kick panels. But I will double check tomorrow. N.C.! I love it. I vacationed to Cape Hatteras last Sept after peak season...it made me want my bronco on cruising up there. Maybe next year she'll be complete so I can drive her back there.
BobbyA
Definitely do one part at a time. Do the floors first and make sure they are welded in good. Then go ahead and tackle the rockers. By doing them separate it makes everything a little more solid so that nothing really goes out of alignment. Make sure you do one side at a time also.
Broncitis
MEB Founder
It is best NOT to do this of the frame. You want to keep the body in proper alignment as best you can, removing it from the frame can add some twist/taco or other tweeks that will screw you up!
We just put a full front floor pan set, striker posts, striker supports and rockers (OEM style outer only) on our current project. The floors fit pretty nice, but the one rocker was spot welded a bit off which required some modification to make the gap to the fender acceptable. We cut out one side at a time and used a ton of Clecos to hold everything together and check fits before we started welding.
After that was all done, we pulled the body and mounted in onto the rotesserie so we can scrape the undercoating to prep the tub for a full soda blasting to get it to bare all to bare metal. That's as far as we have gotten so far.
