Floor Pans
BRONCOFEVER
Raleigh, NC
I've seen a guy on E-Bay that sells floor pans named Marshall. Just wondering if anybody has tried these pans and of they fit OK. If not, does anybody have any recommedations. I've heard that the JBG pans fit pretty well. If inexpensive pans work OK then great, but if they are a pain in the butt to get to fit right, I'd rather spend the extra cash for ones that will go in easy. Time to fix some holes on the old rust bucket before winter sets in.
SteveL
Huge chevy guy
Hawthorne ca
I bought a 4x8 sheet of 1/8" diamond plate for $45 and made my floors. I still have lots of extra material for more perts. Pretty easy to do.
Blue71
If you'll take measurements yourself and get a couple of angles, you can get a local mechanical or metal place to bend and cut them. Mine were $ 40.00 metal and all. I did them my way because Jeff's and everyone else's pans didn't cover a large enough area to cover what I needed, plus I made them a litle thicker for good support. This way I set them in and all the rust was covered by one solid pan. If you want the ribbed factory look, you might have to get them from Jeff's, etc...Let me know if I can help.<br><br>Good Luck,<br><br>Blue71
thesnake
I've considered those myself, but I've been waiting for someone else to bite the bullet then post it here.<br><br>snake
76broncola
Carlisle, PA
The problem with getting floor pans to fit is that even if the pans are perfect, You're going to try to weld them into a truck that has begun to rust out. Floors shift and sag a little, body lifts cause the crossmembers to bow, then the floors don't fit right and you end up pounding on your expensive pans in order to get them to fit. My advice buy lots of sheet metal and have a local shop bend em up for you. Mine cost me 45dollars in parts and labor, and I didn't feel bad if I had to wack em a bit.
thesnake
I don't think the one's on ebay were ribbed. That is a good point.<br><br>snake
swood
San Jose, CA
JBG floor pans worked out great. Had to do a little (very little) amount of trimming but they went in with little trouble. The zinc coating is nice too. I replaced my tunnel cover with my own custom bent piece and now four weeks later (still havent coated the floor) the new custom piece is covered with surface rust. The JBG floor pan is in like new condition.<br><br>Good luck.
