Floor rust to rust-proof
Torkman66
New Braunfels, Tx
Thought I'd take the time to offer a bit of my experience regarding repairing these old rusty rigs. I have replaced floors, qtr panels, and just about everything else on Mustangs, VWs, Jeeps, Dune Buggies, and now a Bronco. 40 years ago I bought what I thought was a great deal on a 1966 convertible mustang. Once I got it home I noticed the floors were pretty much just a sheet of old plywood. I just did not know what rust could do at that point in my life and had no idea how much work it takes to repair and keep it from rusting again. VWs are probably the worst for rusty floors because they have a "pancake floor" that holds all the water, spills, and anything else. They are however, easy to replace. The Bronco is almost exactly like the early mustangs in terms of floor rust except that the mustang is a uni-body which makes it a bit harder to repair. The Bronco is pretty straight forward especially if you are doing a body off. There are many ways to do this job, some work great and some do not. What I have found is pretty simple.
Phase 1: sand blast to bare metal top and bottom, hit everything with two wet coats of good epoxy, cutout any rusted or questionable metal and weld in new specifically stamped (when available) metal. Weld solid lines then seam seal all overlaps and any welds. Apply two more coats of epoxy on all the welded areas.
Phase 2: Once ALL of the rusty metal is gone, and everything is covered in a quality epoxy, you can then determine what you want to do with the surface. There are soooo many opinions on what to do and what not to do and I have pretty much tried most of them. For the under-carriage, I strongly suggest not using any form of textured finish or undercoating. It actually can hold moisture, is very hard to clean, and if small cracks occur, you cant see them and moisture will find its way in. Plus I think it kind of hides all the great metal work you've done :) So I always go right over the top of the epoxy with 2 or three wet coats of satin black. 2K is the best product, but I have also used the Tractor and Truck Implement paint and added the hardener with great results and it is much cheaper. Dries very hard and is easy to touch up if needed.
Phase 3: For the interior surfaces, lots of more opinions. If you plan on going topless (suggest no carpet), then you are better off with a "coating" that can take both abuse and is waterproof (if applied correctly) in case you get caught in the rain. I have used Monster liner (great stuff and super easy to apply with a roller), Raptor is great and is sprayed on, super easy, and looks amazing. And of course the various brands of undercoating which I 100% do not recommend. If your going to prepare your interior for top off use, I suggest Monsta or Raptor. If you can afford it, LineX is also great and they will charge you plenty for it.
If like me, you are going to have a top and carpet, then there are a few considerations. First the epoxy coatings you have on the floors will likely be all that is required to ensure the floors NEVER rust again. I'm sure there are those that live on the beach that might still have an issue, but if Ford would have used epoxy on the floors from the factory, we would not be replacing so many floors today. So for me, the next questions is about sound and heat. I like sound deadener. It has a mastic backing and a foil top. It helps a lot with both road sound and floor heat. Yes it covers up your nice metal work, but so will the carpet. If your like me and have hundreds of pictures of your build, there will be no doubt if you ever want to sale it that the floor sound deader IS NOT hiding anything but sound and heat. BTW, the moden sound deadner has no smell. Dont try to use the roofing mastic at the bib box stores because its cheaper...it has a different chemicals with more petroleum in it and it will smell for a very long time. The modern auto sound deadners have no smell within 2 days of install. One of the main benefits besides sound and heat is that is waterproofs your already tight floors. If you put the sound deadner on every inch, roll it flat with a wood roller, no spills on the floor will ever touch any metal...ever! But this is a one-way street. Once its on the floor, its not coming off. No problem for me in that I like the quieter ride and less floor heat from the drivetrain. I also put it inside the doors. Makes them actually sound like a real door closing rather than a tin can. On the rear cargo floor I also put down some closed cell 1/4" foam sheet that softens the ridges and makes the carpet lay nice and flat.
On top of that you put your carpet (I really like Toms premium one piece BTW). So if anybody is starting this journey, hope this helps generate some ideas. Like I said, lots of ways to do this, and many opinions on what to do and what not to do, this is what has worked for me for many rigs over many years.
gnsteam
Lincoln NE
Really good information. Now you have me rethinking my plan for the under body paint. The shop doing the restoration, likes using Lizard Shin with ceramic. It's probably to late to change my mind though. I'm out of town and they were ready start the painting this week. Either way, I appreciate the advice.
Thank you
