Bronco Paul
- Nov 18, 2006
- 266
Ok...even thou the topic has been covered more times than I can count...could we possibly get all of the questions out in the open and answer them?
First off we all know that there are two front axles found in the EBs...Dana 44 and Dana 30.
Now I'm sure I'll screw this up...so please feel free to correct me...I just want to get a complete guide put together so that it might be put in the FAQ area and never have to go down this road again!
Ok...that being said...
Dana 30s were put in EBs from 1966 to 1970.
Dana 44s were used in EBs from 1971 until 1977.
I know there is a cut off date somewhere in there...was it halfway in 1970 or 1971?
Next question...
What else were the axles put into...?
Ford full size from when to when?
Chevy from when to when?
Jeep from when to when?
Scout?
Others?
I know that the Jeep axles are the narrowest and that the EB are like 1.5 inches wider...what about the full size Fords or the other makes?
Now for conversions...
I know that the all Ford Dana 44 conversion uses pretty much everything from a 1979...does that cover F150s from 1976 up until when?
The Chevy conversion uses the spindles, calipers, brake pads, and backing plates from a late 1972 until an early 1975 4X4 and the rotors and hubs from a Ford...1976 until ? Ok...it's late...what did the bearings and hoses come off of...I think you grab those off of the Chevy as well...?
Ok...those are the only two conversions I hear about...what about Jeep?
Jeep used the Dana 30s in a ton of vehicles...most having Discs...can these be used? I've heard rumors that the spindles are the wrong diameter to be used with the Ford hubs? ...but then Jeep had at one point the same lug pattern as Ford...I think on the older Jeeps...so can those rotors and hubs be used?
Now the stuff never talked about...
Are there any differences in rotor diameter? Did some come with 10 inch while others 12 inch?
Are the drum spindles used in any disc setup?
A list of all of the diameters might be helpful...
Ok...I think thats a good start...so help me out and lets get all the facts collected about the brakes and axles...
Next question...
Scout?
Others?
