Ford 351 Windsor Block/Alum Heads/Forged/Built Motor - $3000
barronj
***Not my ad, just saw it & I'm passing it along to y'all. Obviously, there are questions about streetability & compression, but seller can field that***
http://austin.craigslist.org/pts/1724004556.html
I've got a brand new (literally still in wrap) 351 Windsor sitting here that needs to go. It's actually a very nice build, from the aluminum heads to roller cam and forged pistons. I'd take pics but it's literally wrapped in plastic so you wouldn't be able to see much, but the motor has never been installed or run.
Run down:
Aluminum Heads
New ARP Head Bolts
New Pro Comp Roller Rockers
New Lifters
New Comp Cams Roller Kit
New Moly Push Rods
New KB Forged Pistons (.030" Over) w/ Moly Rings
New Main, Rod, Cam Bearings
New Roller Timing Set
Gasket Kit
New Oil Pump
New Freeze Plugs
Oil Pan
PP Hurricane Power Plus Intake Manifold
Fresh labor:
Magnafluxed Block/Heads
Vat/Clean Block & Accessories
Bore/Hone Block
Deck Block (Square)
Install Bearings
Install Freeze Plugs
Crank Grind
Balance Entire Rotating Assembly
Build Long Block
Build Heads w/ New Rockers
Price dropped from 4500 to 3000. I want it gone, period.
CALLS ONLY. 512.497.0312, ask for Clay.
