- Apr 26, 2015
- 2,734
I have a stock 1977 rear end. I cut the ends off and added the big bearing ends and 31 spline axles years ago. Wilwood makes their rear kit for either 2.00 or 2.36 offset, I have an oddball axle offsets of 2.125", what I can't figure out is how this offset is set? Is it from the axle design? How far the bearings are pressed on? Spline depth? From what I can see, the axles are semi floating?
I ended up buying the 2.36 kit, thinking I could simply space out the bracket, but that won't work, the drum parking brake ends up hitting the back side of the arp wheel studs. I can get bearing spacers, that push out the axles, but I don't have enough spline left to space it out the .235 I need. I have roughly 1" of spline engagement now, so spacing out a 1/4" isn't an option.
Any thoughts?
To make things worse, I narrowed my rear end years ago to clear 285/70-17s, but now I don't have that setup, I run .25" spacers, which gives me the look and clearance I like. Moving the axles out that amount and spacers will give me roughly .5" out from my cut off of 1" per side. Which might be even better.
I can't seem to find any axles that state 2.36 offset or anything like that. Is the offset from axles, bearings, or even the welded on ends?
Any thoughts?
