Nothing Special
- Nov 25, 2016
- 841
I wouldn't eliminate a good limited slip from your options.
Sure you'll need to add friction additive, and the clutches aren't totally maintenance free. But auto trannys use clutches too, and that hasn't kept anyone from using them.
Yukon makes a great limited slip unit. You can select from two different lock-up pressures.
The thing I like about an LS over the True Trac is the LS will still work if you get one wheel in the air. With the True Trac, you have to tap the brake to get it to lock up.
My reason for not thinking a limited slip (other than a gear-type like the TrueTrac) is an acceptable option doesn't necessarily apply to everyone. But when going around a corner, even if just coasting, if the tire traction isn't good enough to slip the diff, then the tires slip. So when coasting around a corner on ice or snow it can cause you to swap ends.
In my experience there's no acceptable "window" of performance for limited slips. Even the worn out one when I bought my F-250 with 161K miles was still too tight to feel safe in winter driving, but definitely too loose to be helpful when I needed it.
If driving on slippery surfaces isn't a factor, then maybe a limited slip can be a good choice for you. But i certainly don't recommend them.
